Patrick Laidlaw Mon, 04/24/2006 - 23:47
  • Gold, 750 points or more
Two ways to do this one is an outgoing access-list on your inside interface the other is set your vpn match access-list to just allow tcp port 80. So on you "ab" acl add eq 80 and you'll only traffic destined to port 80 will be allowed down that tunnel.
access-list ab extended permit ip 10.192.0.0 255.255.0.0 10.100.24.0 255.255.248.0 eq 80
Patrick
Please rate any posts that are helpful.
Fernando_Meza Tue, 04/25/2006 - 00:24
You can control by modifying the access list been used for the interesting traffic ( Traffic that will be encrypted ). You need to make sure the change is performed in both PIXes.
PIX1.
access-list VPN-L2L-Access permit tcp x.x.x.0 255.255.255.0 y.y.y.0 255.255.255.0 eq 80
PIX2
access-list VPN-L2L-Access permit tcp y.y.y.0 255.255.255.0 x.x.x.0 255.255.255.0 eq 80
Also this traffic has to be exented of NAT and allowed on any access-list you might have appied to the respective internal interfaces.
