Warning message
bgp load balancing
Apr 25th, 2006
I have two internet links connected two different routers and running hsrp between them.
internet link connected to hsrp active router only utilised and the link connected to standby router sitting idle?
I am thinking of loadbalancing of two links ?
the option i am thinking is traffic exit thro ACTIVE hsrp router and enter thro' standby router is this option will serve my purpose ? if not any suggestion ?
Rajesh
pkhatri Tue, 04/25/2006 - 03:27
  • Purple, 4500 points or more
Hi Rajesh,
Why don't you create two HSRP groups with half your workstations pointing to one and the other half pointing to the other ? That way, you will not have to have traffic undergo unnecessary hops through your active router.
You will still get redundancy when one of them fails - all traffic will just switch over to the other router.
Hope that helps - pls do remember to rate posts that help.
Paresh
rajeshk200_2 Tue, 04/25/2006 - 03:33
I have redundant firewalls behind the hsrp routers.
hsrp virtual IP acting as gateway for both the firewalls.
the option you suggested will not fit into my environment.
Rajesh
pkhatri Tue, 04/25/2006 - 03:36
Rajesh,
Then what you need to do is to run IBGP between the two routers. You will need to manipulate the Local Preference of the internet routes so that the first router is the preferred exit point for these routes and the second routers is the preferred exit point for the others.
Paresh
rajeshk200_2 Tue, 04/25/2006 - 03:47
Hi Paresh,
we have both the links from same ISP. is it possible ask provider to route the incoming traffic thro hsrp standby router link?
anyhave link in the active router used for exit traffic.
I am just thinking, but i am not sure this is possible or not.
if yes is this work without any issues or will create asymmetric routing?
Rajesh
