CiscoWorks VMS "Server Certificate Expired"
Apr 25th, 2006
I'm getting a message saying my Server Certificate Expired when I use Management Center for IPS Sensors.
I found bug CSCsa88926 that has Workaround:
Generate a new SSL certificate:
Stop the daemon manager (net stop crmdmgtd)
$INSTALL_ROOT\CSCOpx\MDC\Apache\conf\ssl
run:
..\..\gencert
Restart the daemon manager (net start crmdmgtd)
But this fails to generate new cert keys.
Anybody have any idea what to do?
ishah Thu, 05/04/2006 - 16:40
there is a command line gen cert command to let you generate a new certificate.
I can't remember the exact syntax but I have used it in the past to generate a longer lifetime certificate than the default - I'm sure you will find it somewhere on CCO
