VPN client PC can receive the settings from the PIX firewall
Apr 25th, 2006
Hi All,
I am trying to setup an IP Pool on a different subnet than my local LAN. If I setup a vpn pool using my internal LAN addresses everything works fine.
When I use an IP Pool other than my local LAN, I can connect to the PIX and the VPN client PC can receive the settings from the PIX firewall, however I am unable to see the local LAN.
Below is the config, am I missing a route or an access-list?
All help gratefully appreciated.
PIX Version 7.0(1)
names
interface Ethernet0
nameif Outside
security-level 0
ip address 192.168.10.253 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 10.10.10.253 255.255.255.0
interface Ethernet2
nameif DMZ
security-level 50
ip address 131.131.x.x.255.255.0
enable password xxxx
passwd xxxx
hostname pixfirewall
domain-name wtm
ftp mode passive
clock timezone EST 10
access-list Outside_access_in extended permit icmp any any
access-list inside_nat0_outbound extended permit ip any 10.10.10.224 255.255.255.240
access-list Outside_cryptomap_dyn_20 extended permit ip any 10.10.10.224 255.255.255.240
pager lines 24
logging asdm informational
mtu inside 1500
mtu DMZ 1500
mtu Outside 1500
ip local pool Dial-In 10.10.11.1-10.10.11.239 mask 255.255.255.0
monitor-interface inside
monitor-interface DMZ
monitor-interface Outside
asdm image flash:/asdm-501.bin
asdm location 10.10.10.224 255.255.255.240 inside
no asdm history enable
arp timeout 14400
global (Outside) 10 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 10 0.0.0.0 0.0.0.0
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 192.168.10.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
group-policy try internal
group-policy try attributes
dns-server value 10.10.10.16 10.10.10.2
username xxx password xxx encrypted privilege 0
username xxxx attributes
vpn-group-policy try
http server enable
http 10.10.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map Outside_dyn_map 20 match address Outside_cryptomap_dyn_20
crypto dynamic-map Outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map interface Outside
isakmp identity address
isakmp enable Outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp nat-traversal 20
telnet 10.10.10.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
tunnel-group try type ipsec-ra
tunnel-group try general-attributes
address-pool Dial-In
default-group-policy try
tunnel-group try ipsec-attributes
pre-shared-key welcome
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:xxxx
: end
Overall Rating: 2.7 (3 ratings)
spremkumar Tue, 04/25/2006 - 22:02
  • Red, 2250 points or more
Can you change this and try ?
no access-list inside_nat0_outbound extended permit ip any 10.10.10.224 255.255.255.240
access-list inside_nat0_outbound extended permit ip 10.10.10.0 255.255.255.0 10.10.11.0 255.255.255.0
regds
xbw Wed, 04/26/2006 - 01:03
My last configuration is as following,My client can connet with pix(218.87.6.77 isp address),but still can't ping inside any host.how can i do .help me,thanks!
: Saved
PIX Version 7.0(4)12
domain-name default.domain.invalid
names
interface Ethernet0
nameif outside
security-level 0
ip address 218.87.x.x.255.255.192 standby 218.x.x.76
interface Ethernet1
nameif inside
security-level 100
ip address 168.50.x.x.x.255.0 standby 168.x.x.151
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd xxxx
ftp mode passive
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip any 10.10.10.0 255.255.255.240
access-list outside_cryptomap_dyn_20 extended permit ip any 10.10.10.0 255.255.255.240
pager lines 24
mtu outside 1500
mtu inside 1500
ip local pool hpcisco 10.10.10.1-10.10.10.10 mask 255.255.255.0
failover
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 168.x.x.x.255.255.0
access-group Outside_access_in in interface outside
route outside 0.0.0.0 0.x.x.x.87.6.65 1
username xxxx password xxxx
http server enable
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
tunnel-group hpcisco type ipsec-ra
tunnel-group hpcisco general-attributes
address-pool hpcisco
tunnel-group hpcisco ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 1
console timeout 0
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
Cryptochecksum:xxxx
: end
spremkumar Wed, 04/26/2006 - 02:23
Then create a access-list permitting the traffic from your local lan to the vpn ip pool and bind the same to the nat 0 statement so that the reverse flow dont get natted..
access-list inside_nat0_outbound extended permit ip 168.50.6.0 255.255.255.0 10.10.10.0 255.255.255.0
regds
xbw Wed, 04/26/2006 - 03:05
My last configuration is as following,my user and password are hpcisco,can you connet with my pix and help me.thanks.
: Saved
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 218.87.6.77 255.255.255.192 standby 218.87.6.76
interface Ethernet1
nameif inside
security-level 100
ip address 168.50.6.150 255.255.255.0 standby 168.50.6.151
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
failover
monitor-interface outside
icmp permit any outside
icmp permit any inside
arp timeout 14400
nat-control
nat (inside) 1 168.50.6.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 218.87.6.65 1
username hpcisco password qBAk4em/9YLY0.2x encrypted
http server enable
pre-shared-key *
telnet 0.0.0.0 0.0.0.0 outside
telnet timeout 5
ssh timeout 5
ssh version 1
console timeout 0
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
Cryptochecksum:8cdd22aa73f7a58ebabb7eb0eb20a417
: end
Fernando_Meza Wed, 04/26/2006 - 16:23
  • Gold, 750 points or more
I think you mihgt have some issue with this instruction
I suggest changing it to:
access-list outside_cryptomap_dyn_20 extended permit ip any 10.10.10.0 255.255.255.0
xbw Wed, 04/26/2006 - 19:09
I had changed the access-list,but I still can't ping local pix (inside)and other hosts
