Fix for "The SSL VPN Client driver has encountered an error." msg
jasonlow
Anyone know a fix for the "SSL VPN Client driver" error? Issue appears to be specific to a recent update to the PC; others are working fine.
beth-martin
Level 5
Level 5
revert the RipCount value to 5 for the Novell Client:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NwlnkIpx\Parameters]
"RipCount"=dword:00000005
or the problem may be due to the lower version of concentrator image.
What has this got do with the SSL VPN-client problem???
Changing the IPX RipCount to 5 fixed the problem. Thanks!
