backup link test
Apr 26th, 2006
Hi everybody,
I've tested the attached backup link configuration (conf_test.txt) using 2 routers with VWIC 2T on each, connected by CAB-SS-2626X.
Actually, we should use T2 as main link and leased line as backup.
The current config on the router where i should configure after testing is also attached here (current_conf.txt).
I'd like to know how can I simulate this scenario before configuring it on a live network?
is there any change to do on the test config when we use T2 and LL
mastram4u Wed, 04/26/2006 - 23:19
As you did in the test config, you need to specify the route without AD for the primary and with AD for the backup link.
Hope that helps.
harinirina Thu, 04/27/2006 - 06:26
Thanks for the reply.
in the live network, we use VWIC-1MFT-E1 but not VWIC-2T.
I'd like to ask you if there's some modification to do in the config when i use other card or other protocol
