Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927661members
1240587discussions
Community Activity
Client status locked in "Web Auth Pending" on WLC 9800-40
Hello all,   I'm having an issue with clients connected on my Guest SSID configured with Web Authentication Splash Page. Basically by today (NO CHANGES NOR ACTIVITIES WERE DONE) all the clients which are trying to connect to this SSID cannot reach th...
Simone C by Level 1
  • 38 Views
  • 2 replies
redundancy in core layer
hi guys . i have a network with below topology. In the core layer, I want to have redundancy, which means that if the main core switch of my network has a problem, the backup switch will automatically enter the circuit. What method is there?
chpmotry by Level 1
  • 93 Views
  • 7 replies
C9800 WNCd
i've seen this item "Site Tags AP to WNCd distribution" in best practice of C9800 Design and Deploymentmy quiestion is how can i configure multiple WNCd and where is the location of settings in webui?
Felix5 by Level 1
  • 103 Views
  • 3 replies
Mobility Express Upgrade Failure
Hello, I am in the process of updating a Mobility Express WLC from Cisco. I have deployed the TFTP server and the correct images and the pre-download worked on all access points except one. In the following picture you can see what output I get. I l...
mgollob by Level 1
  • 75 Views
  • 2 replies
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 210 Views
  • 9 replies
Installing Secure Client (5.x) AND Any Connect (4.x) on 1 computer
I have a weird situation I need to connect to two sepaate VPN (not at the same time).One of these requires Cisco Secure Client 5.x the second works with Any Connect 4.x.I have Cisco Secure Client 5.x installed, if i try connecting to the VPN that use...
marcobat by Level 1
  • 126 Views
  • 4 replies
Changing wsa data ip
Hi all,We had WSA appliance and we are migrating appliance to virtual environment.We have configured new WSA and tested and its working fine and now we are planning to move it to LIve so we are planning to change the data ip.of new virtual WSA to the...
SIB9 by Level 1
  • 30 Views
  • 1 replies
10mb connections
Hello,On the newer switches with 2.5/5gb ports how do you handle devices that only work with a 10mb NIC?We have a HVAC controller that only has a 10mb NIc on it so the switch doesn’t detect it. Is there a device that will convert down to 10mb like a ...
pollardt3 by Level 1
  • 30 Views
  • 1 replies
One-way Audio following IP Address Change
I've recently inherited a new network as part of beginning a new job.  Historically, my exposure to voice is pretty limited.  Without getting into the details of what lead to it, as it's not relevant, after performing a reset on an 8851, the phone gr...
robo764 by Level 1
  • 30 Views
  • 0 replies
vfmc-7.4 cannot deploy ovf
Dear TeamI have downloaded the vfmc for esxi 7.4.X and 7.3X but i cannot deploy in VMware after deployment its retturn "operating system not found"any ideaRegards
Resolved! A question about MAC addresses for access points
Can anybody tell me what exactly is the difference between the radio MAC address vs the ethernet and Wi-Fi mac addresses? What is the purpose of the radio MAC address? Apparently, wireless access points don't just have an ethernet and Wi-Fi MAC, but ...
Jibroni by Level 1
  • 157 Views
  • 4 replies
