Warning message
Installing SDM on a 1711 Router
Apr 26th, 2006
hello, I am having trouble installing any version of the SDM on a 1711 router running [C1700-ADVSECURITYK9-M Version 12.4(2)T]. I have tried several code versions with no success. The error message I receive when the installation fails is "This router model is not supported by SDM. Please enter the IP address of a router supported by SDM". All the documentation I find from Cisco says that this device supports SDM. Release Notes for SDM says the same thing.
Please help
Fernando_Meza Wed, 04/26/2006 - 19:45
  • Gold, 750 points or more
Hi if you are trying to install SDM version 2.2 then it shoudl be OK .. it does support 1711 router
Fernando_Meza Wed, 04/26/2006 - 19:47
IPs supported for this router is Cisco 1711 12.2(15)ZL or later
reswaran Thu, 04/27/2006 - 22:05
  • Cisco Employee,
When are you getting this message? Can you send the output of "show version" to help you better.
Ravi
cfreebourne Fri, 04/28/2006 - 04:48
I am getting the message after I enter the ip address and credentials in the SDM setup dialog.
Sho ver
Router# sho ver
Cisco IOS Software, C1700 Software (C1700-ADVSECURITYK9-M), Version 12.4(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 23-Jun-05 23:03 by kellmill
ROM: System Bootstrap, Version 12.2(7r)XM4, RELEASE SOFTWARE (fc1)
Router uptime is 34 minutes
System image file is "flash:c1700-advsecurityk9-mz.124-2.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco IPM (MPC862P) processor (revision 0x101) with 114688K/16384K bytes of memory.
Processor board ID FOC08251QBP (1922194817), with hardware revision 0000
MPC862P processor: part number 7, mask 0
1 Ethernet interface
5 FastEthernet interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Router#
reswaran Mon, 05/01/2006 - 20:13
  • Cisco Employee,
The "show version" put put is not showing it as 1711.
It should be
Cisco 1711 (MPC862P) processor
Ravi
cfreebourne Tue, 05/02/2006 - 05:05
Could this be a firmware issue. The router shell says 1711. I am not sure how I can get the sho ver to say 1711 or how to verify that it is not a 1711.
cbumgardner Sun, 06/10/2007 - 14:24
I have this same problem. The router says it is a 1711 on the cover but show version reports Cisco IPM not Cisco 1711. I can find no documentation on a model Cisco IPM.
cfreebourne Mon, 06/11/2007 - 05:07
I never got a resolution to my issue. I was using the router for some certification prep. After my tests were over I didn't pursue the issue anymore. Sorry, hopefully your router is under a smartnet and you can call Cisco on it.
cbumgardner Mon, 06/11/2007 - 11:08
From what I can tell 1711 and 1712 are the same, the only difference is in 2 modules. How does a router know what model it is supposed to be? If it has WIC-1B-S/T in slot 1, it it a 1712. If it has WIC-1AM in slot 1, it is a 1711. If it has nothing, it just sits there confused about its identity and you get the IPM. I dumped the strings in found in IOS and found the names based on modules loaded and IPM was listed with no modules loaded. This is only a problem when using Cisco management tools.
Cody
