Warning message
Callmanager install keeps failing
Apr 26th, 2006
Folks,
I am trying to install callmanager 4.1(3) and i keep getting this error.
ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(S): ISSCRIPT_VERSION_OLD = The InstallScript engine on this machine is older than the version required to run this setup. If available, please install the latest version of ISScript.msi, or contact your support personnel for further assistance.
What should i do?
Chris Deren Wed, 04/26/2006 - 15:30
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Is this a new install or an upgrade?
If this is an upgrade run the upgradeAssistantUtility version 4.1(3) before running the setup.
Chris
gogasca Wed, 04/26/2006 - 19:51
  • Green, 3000 points or more
Hi Parwal,
Please upload the complete log file, and check the following:
1. Make sure that you have HOST and LMHOST files on both the servers i.e. PUB and the SUB
2. Install Windows OS 2000 2.7|2000.4.2 and then lastest SR
http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des
3. Install CCM 4.1.3
4. Is this a PUB or a SUB?
5. How many you have attempted the Installation?
NAVIN PARWAL Thu, 04/27/2006 - 00:39
Many thanks for a very useful response. I will surely rate this post. I have also attached the installation logfile. I am trying to install a Sub on a IBM server which was not bought dirtectly from Cisco but is on the approved list of supported hardware for 4.1(3). I installed windows 2000 server followed by an upgrade to 2000.2.7 and then the 4.1(3) installation. Any advice would be highly appreciared.
thomas1 Thu, 04/27/2006 - 12:20
I had a problem loading the IPT OS on IBM 346's last year. This link may be helpful as it helped me.
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/products_tech_note09186a00804d7456.shtml
In addition to this link, I did the following because I changed so many settings trying to get it to install...putting the servers back to factory settings helped before following the procedures on from the above link:
put drives in slots 0 and 1
boot to setup (F1) and restore all settings back to default
reboot and use the "mini configuration" tool when the option is available...right after the system sees the RAID controller. the command is ctrl + i
once in the mini config tool, restore everything back to factory settings and reboot with the hardware detection disk in the drive.
do not create the logical drive. let the hardware detection disk do it. you should see some text scroll across the screen saying "found controller" "created logical drive" etc. Use the "pause print screen" button to see it. press enter to continue.
Hopefully, this will help. Something else to be aware of, unless IBM is fixing this in their servers now, is a problem with the NIC's changing "sides". You configure NIC 1 and after a reboot, those settings appear on NIC 2...it's weird. I don't know if IBM fixed this problem or not. Either way, I have a feeling the 2000.2.7 disk will over ride whatever BIOS fix IBM applies from the factory. Cisco probably provides the fix in an SR or separate download.
