Warning message
GLC-T= with 3750-24TS
Apr 26th, 2006
Does anybody know if the GLC-T= 1000Base-T SFP module works in a 3750-24TS switch? And if it does, can I bond 2 GLC-T modules in an etherchannel pair connected to a 3750G-24T switch?
Diego
atif.awan Wed, 04/26/2006 - 21:38
  • Silver, 250 points or more
Yes it is supported. Please check the compatibility matrix at:
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_device_support_table09186a0080446625.html
I do not think you should have any issues in bonding them to other UTP ports in a second switch. That being said it is always good to test this in a lab before trying in production.
DIEGO ALONSO Thu, 04/27/2006 - 04:36
Wow, that table is confusing. There are two columns, one labeled Catalyst OS and the other called IOS. The 3750 family shows "not supported" in the Catalyst OS column and a minimun IOS level in the other column. Which column should I be looking at? Can a device have/run both types of OS?
Diego
atif.awan Thu, 04/27/2006 - 07:35
Ignore the CatOS column for the 3750s as these switches run the IOS only. Of all the existing Catalyst switches only the 6500 series (AFAIK) are capable or running CatOS (called Hybrid mode) and IOS (called Native mode).
Hope this helps.
