Warning message
one adsl network question
travis-dennis_2 Fri, 05/05/2006 - 05:07
  • Gold, 750 points or more
There isn't a lot of information to go on here but one question is if your ISP allows static IPs? If not and the DHCP leases are for 30 minutes at a time then it is possible you get disconnected once your ISP sees you have assigned a static IP. Just a wild guess though. If you want to give some more information such as the ISP, router model, ADSL card, and post a snatized config then I am sure someone here will chip in with some information.
Hope this helps.
Please remember to rate all replies
