Warning message
How to synchronize between DHCP binding table and DHCP snooping table ?
Apr 27th, 2006
I clear DHCP snooping table with command "clear ip dhcp snooping binding " , and PC can't communicate with other any more. So how to synchronize between DHCP binding table and DHCP snooping table ?
dhcp-test#sh ip dhcp bind
IP address Client-ID/ Lease expiration Type
Hardware address
99.1.65.32 0100.1125.353c.25 Mar 02 1993 01:05 AM Automatic
99.1.65.33 0100.1438.059f.85 Mar 02 1993 12:01 AM Automatic
dhcp-test#sh ip dhcp snooping binding
MacAddress IpAddress Lease(sec) Type VLAN Interface
Total number of bindings: 0
thanks!
thomas.chen Sat, 05/06/2006 - 06:38
  • Silver, 250 points or more
ip dhcp snooping binding mac-address vlan vlan-id ip-address interface interface-id expiry seconds
Add binding entries to the DHCP snooping binding database. The vlan-id range is from 1 to 4904. The seconds range is from 1 to 4294967295.
Enter the above command for each entry that you add
To delete the database agent or binding file, use the no ip dhcp snooping database interface configuration command. To reset the timeout or delay values, use the ip dhcp snooping database timeout seconds or the ip dhcp snooping database write-delay seconds global configuration command.To renew the database, use the renew ip dhcp snooping database privileged EXEC command.
