GRE/IPSEC
Apr 27th, 2006
  • Bronze, 100 points or more
does anyone know the place to start with the configurations on GRE/IPSEC using EIGRP on 3360 as Main and 1821 as Remote Routers. samples or configuration setups links would be helpful
Overall Rating: 4 (1 ratings)
rais Thu, 04/27/2006 - 05:18
  • Silver, 250 points or more
Once you can ping site to site, start configuring GRE tunnel. Then use GRE interface IPs to create IPSec crypto maps.
Hope this helps.
zulqurnain Sat, 04/29/2006 - 08:40
thanks, but that was the point as if anyone can point some good links to read out and start the configuration or sample configurations.
