sarah12345 Thu, 04/27/2006 - 17:46
Hi Sean,
Yes, it is QinQ tunneling. I am using Cat6k-Sup720.
Cisco7606(config-vlan)#?
VLAN configuration commands:
are Maximum number of All Route Explorer hops for this VLAN (or
zero if none specified)
backupcrf Backup CRF mode of the VLAN
bridge Bridging characteristics of the VLAN
exit Apply changes, bump revision number, and exit mode
media Media type of the VLAN
mtu VLAN Maximum Transmission Unit
name Ascii name of the VLAN
no Negate a command or set its defaults
parent ID number of the Parent VLAN of FDDI or Token Ring type VLANs
private-vlan Configure a private VLAN
remote-span Configure as Remote SPAN VLAN
ring Ring number of FDDI or Token Ring type VLANs
said IEEE 802.10 SAID
shutdown Shutdown VLAN switching
state Operational state of the VLAN
ste Maximum number of Spanning Tree Explorer hops for this VLAN (or
stp Spanning tree characteristics of the VLAN
tb-vlan1 ID number of the first translational VLAN for this VLAN (or
zero if none)
tb-vlan2 ID number of the second translational VLAN for this VLAN (or
zero if none)
Sarah
sarah12345 Fri, 04/28/2006 - 08:42
Hi Bobby,
Thank you very much for the link.
The following is my config.
SUT === Cisco --- Traffic Generator #1
Traffic Generator #2
SUT: System Under Test
LACP is enabled between the Cisco and the SUT.
Traffic Generator #1 sends multicast traffic
with VLAN tag through Cisco to the SUT.
Traffic Generator #2 sends stacked VLAN (QinQ)
traffic through Cisco to the SUT. So Cisco is
expected to pass through all the traffic (with
one or two VLAN tags).
Currently, I don't even see any frame count
at the Cisco interface which is connected to
the Traffic Generator #2.
Sarah
