Warning message
djbradley Thu, 04/27/2006 - 08:57
No pun intended but it's for Management. Why is it 1 gig? Why not?
Once the module is installed and configured this is the port you will connect to through ADSM. Do a "session 1" command on the ASA to access the SSM, type setup, and follow the prompts. Once you give the module an IP address and reload it you will be able to access the module via ADSM.
