IOS number translation
Apr 27th, 2006
Voip Network: PBX connected to Cisco3800 using NMHDV; router working as voice gateway.
When my extenion makes call thru Cisco, router sends the actual CLI (043664741)to other h323 router. I want this 'specific' CLI to be translated to another series 08718553333.
i have to use translation rule or profiles...but some how it is not working.. any help..
Overall Rating: 4 (1 ratings)
anup.anand Thu, 04/27/2006 - 12:11
  • Silver, 250 points or more
Please paste your configs.
regards,
Anup
Brandon Buffin Thu, 04/27/2006 - 12:14
  • Purple, 4500 points or more
You could use a combination of a translation rule and a translation profile which then is applied to a dial peer, such as:
voice translation-rule 3
rule 1 /043664741/ /08718553333/
voice translation-profile profile1
translate calling 3
dial-peer voice 10 pots
translation-profile outgoing profile1
Voice Translation Rules
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Hope this helps. If so, please rate the post.
kumarss77 Fri, 04/28/2006 - 10:42
since its for out going calls, i guess should apply translation-profile outgoing profile1 on the 'voip dial peer' am i correct..
though i did that and tested stll translation wasnt happening place.
i am posting the config attached.
anup.anand Sat, 04/29/2006 - 10:52
The translation rule looks good. Apply it to the dial-peer, as below
dial-peer voice 1000 voip
translation-profile outgoing skyi
Anup
