04-29-2006 11:55 AM - edited 03-13-2019 01:07 PM
Hello, not sure if this is the correct place for this post, but...
Does anyone know of a replace for # when you want to send the digits out from a IP phone?
In analog phone, if I dial a number I can send a termination character # to make things faster.
How can I do the same on the IP phone?
2> If someone calls me on a IP phone, and I want to end this call without answering it or sending it to the voice mail, is there a way?
Vlad
04-30-2006 10:01 AM
Vlad,
Is this CCME or Callmanager ?
In CCME, you have a built in softkey called DND which, when you push it will silence the call, and if you have a CF setting (to voicemail), pushing the DND soft key will send the call straight to voicemail.
In Callmanager, unfortunately DND is available only with IPManager/Assistant feature, where you can divert all calls to Assistant, and she may transfer them to voicemail or answer the call for you!
Sankar
PS: please remember to rate posts!
05-01-2006 05:33 AM
Hi Vlad,
Here is a little more information for you;
1>
END-OF-DIALING
This single character identifies the end of the dialed-digit string. The # character serves as the end-of-dialing signal for international numbers that are dialed within the NANP.
From this doc;
2>
Immediate Divert
The Immediate Divert feature allows you to immediately divert a call to a voice-messaging system. When the call gets diverted, the line becomes available to make or receive new calls.
From this doc;
Hope this helps!
Rob
Please remember to rate helpful posts.........
05-02-2006 08:20 AM
thanks for the replies,
unfortunatelly, Immediate Divert wont solve my problem (Ive tried this before). I would like to end the call without answering at all (dont send it to VM).
And the # didnt work , this is why Ive posted here to find a different solution.
I'll try it again and test to see what is causing the problem.
Thanks again,
Vlad
