Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926400members
1238202discussions
Community Activity
Cisco 9300X Static routes don't work to SVI Tunnels
NOTE: I have done the same test setup with 4000 series routers, and routing works fine.I have successfully setup 3 SVI (Static Virtual Interface) tunnels with IPSEC between 2 9300X switches.- I can ping the tunnel IPs- I can ping each VLAN interface ...
DMVPN issue with 800 series routers
I have a DMVPN network with 4331 hub routers. Our HQ in Memphis has a hub on AT&T, and another on Lumen. Our New York hub is also a Lumen connection. All are 500Mb up/down. We have about 35 spokes around the US that peer to all 3 routers. BGP is the ...
applyTransParams question
Hi,Maapi.commitQueueResult is deprecated and we should use applyTransParams.I need help on how to use applyTransParams.I have the following code:CommitParams cp = new CommitParams();cp.setCommitQueueSync();cp.setNoOverwrite();CommitQueueResult result...
sm000x by Level 1
  • 7 Views
  • 0 replies
Unable to get console access on switch 3850 - Blank terminal
Hello,I have a switch I am unable get a prompt on the console port.I can SSH to it, and have confirmed that the baud rate and stop bits are correct from the console switch. There are two other switches that I can console to.The differences are that t...
mrjelly by Level 1
  • 82 Views
  • 5 replies
Resolved! AnyConnect 4.10 upgrade to Secure Client 5.x
I need to upgrade AnyConnect 4.10 because it is EOS on 3/31/24.  The replacement product is Secure Client 5.x.  Currently, users only have DART and NAM installed on their computers.1. Do I need to uninstall AnyConnect 4.10 or is that automatically do...
tachyon05 by Level 1
  • 2193 Views
  • 9 replies
The 'vlan database' command is not working on the 2690-24TT switch
Hello everyone,I am a teaching assistant at an university. I'm using Packet Tracer to configure VLANs based on MAC addresses, but when I try to use the 'vlan database' command, I encounter the following error:Switch#vlan database^ % Invalid input det...
nvertee by Level 1
  • 204 Views
  • 7 replies
