Abbreviated dialing on CME and 7960G
May 2nd, 2006
How do you dial abbreviated numbers on a 7960G? The documented method does not work for me!
I configured abbreviated tags as per the documentation. These codes work like a charm on 7912 phones where the abbr. button is abvailable.
On the 7960G phone the abbr button is not available and according to the documentation you are supposed to use a "*" and the code to do the abbreviated dialing. The same goes for analog phones. On neither of these phones (analog/7960G) can I get the abbreviated dialing to work.
I get a fast busy signal and a message on the 7960G stating "unknown number".
s.jankowski Tue, 05/09/2006 - 06:18
  • Bronze, 100 points or more
On-hook abbreviated dialing is limited to Cisco IP Phones 7905G, 7912G, 7920G, 7970G, and 7971G-GE.
thisisshanky Tue, 05/09/2006 - 10:14
  • Purple, 4500 points or more
Shannon is right. If you look at the docs, its surprising that 7960s doesnt support this feature. You would think why?
