Warning message
Dialing with Outlook
May 2nd, 2006
I`ve obtained hoe to dial with outlook on a IP telephone. It`s possible dial using the address book?? I know that is possible programming outlook but i want to try without prgramming, some ideas???
stephan.steiner Wed, 05/03/2006 - 06:15
  • Silver, 250 points or more
If you properly install the TAPI plugin, you should be able to dial from all the dial buttons anywhere in outlook.
As soon as you want to do more, you'll have to think about third party tools that you can buy or create on your own. For instance, opening a contact for incoming calls is something that is not possible with the current TAPI plugin.
