Update ACS 3.3 to 4.0 results in erormessage
May 2nd, 2006
Hi Everyone
Did anyone experience a errormessage when updating ACS 3.3 to 4.0?
We are using Windows 2000 SP4, and recieved the folling errormessage:
ERROR: failed to export user database.
Please check there is sufficient diskpace then rerun Setup.
Setup will now exit
[OK]
We do have more than 30 GB of free diskspace though......
Anyone an idea?
Greetings
Jarle
darpotter Wed, 05/03/2006 - 00:57
  • Silver, 250 points or more
Hmmm, I've seen errors where very large amounts of free disk space caused the calculations to overflow resulting in low disk space warnings. Could be similar.
A long shot... but try making the partition smaller or create a very large swap/page file to use up a chuck of it.
Otherwise its a call to the TAC to register the bug.
Darran
Vivek Santuka Thu, 01/18/2007 - 03:58
  • Cisco Employee,
Some times folder locaked and no space error can be seen if the logs files are too huge.
Try moving the logs files from the ACS folders (Each CS* Folder hsa a Logs Directory).
Vivek
