Warning message
Serial Cable Speed
May 2nd, 2006
In my home lab I have 2 2501's connecting to each other through a back to back serial cable to simulate a WAN between two separate LAN's.
My question is what is the fastest speed I can get out of this sort of connection. Is this set by the clockrate? I would like to share the Internet connection from the one side.
Overall Rating: 5 (1 ratings)
Richard Burts Tue, 05/02/2006 - 09:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jacob
The speed of the connection is directly controlled by the clock rate and is indirectly controlled by the kind of cable inteface that is used. The serial interrface of the 2501 supports several cable standards. If the cable is RS-232 you will have difficulty getting speeds much above 64 K where if you have a V.35 cable you can get speeds of T1 or E1.
Rick
stephtchoko Tue, 05/02/2006 - 09:18
  • Bronze, 100 points or more
the fastest speed is 4000 000 bps (4Mbps).
I confirm thatthis fast speed is set by clock rate.
GN-2500-YDE(config-if)#clock rate ?
Speed (bits per second)
1200
2400
4800
9600
19200
38400
56000
64000
72000
125000
148000
250000
500000
800000
1000000
1300000
2000000
4000000
<300-4000000> Choose clockrate from list above
GN-2500-YDE(config-if)#end
http://www.cisco.com/en/US/tech/tk713/tk317/technologies_configuration_example09186a00800944ff.shtml
Regards.
