Warning message
VPN tunnels between 3 sites.
May 3rd, 2006
I have 3 sites(A,B,C). A is connected to B thro' Site2Site VPN & also B is connected to C thro' Site2Site VPN. All 3 sites use PIX 7.1(1) for VPN connetctions. If I trace C clients from A client, it is only one hop thro' B. Everything working fine so far. Now if I want to add A to C directly on a Site2Site VPN, will there be any issues having double paths to the same locations?(directly & thro' B). Can I give priority on directly connected VPN path always when a packet want to reach that perticular site? Dont want to pass the trafic on the other round about path [A->B->C](even though A to C is 1 hop apart on VPN) unless the direct VPN [A->C] cannot be established for some major reason. I would appreciate if someone can give a solution before I try it out.
