Warning message
Cisco Security device manager (SDM) authentication fails
May 3rd, 2006
when i tried to install SDM on cisco2611 router it is asking for username & password of level 15 so configured a local user of level 15 on the router & provided the same creditentials to SDM installer but the authentications fails can any body pls clarify wht to do in this situation
regards & thanks in advance
Richard Burts Sat, 05/06/2006 - 12:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I believe that SDM typically sets privilege level 15 on the vty. You might try that and see if it helps.
Rick
haris.cisco Mon, 05/08/2006 - 21:05
hi jeff,
there is no firewall in between or running on PC
and i tried your recomendationd but it did not work out.
is it any thing with the version of IOS, BTW i am using c2600-is-mz.12.2-34
regrds & Thanks in adv
