Warning message
Questions on MARS
Overall Rating: 4 (1 ratings)
Fernando_Meza Wed, 05/03/2006 - 22:11
  • Gold, 750 points or more
Hi .. In regards to your question about netflow :
Netflow is a Cisco IOS software feature and also the name of an open (but proprietary) Cisco protocol for collecting IP traffic information. Cisco routers with netflow enabled generate netflow records, which are exported from the router in UDP packets and collected using a netflow collector. Juniper Networks provides a similar feature for its routers called cflow.
Other vendors do support netflow .. you can try netflow analizer for example whihc is not a cisco tool but supports cisco devices.
NetFlow Analyzer from AdventNet
http://manageengine.adventnet.com/products/netflow/index.html
I hope it helps ... please rate if it does !!!
