Warning message
Place call variables
May 3rd, 2006
When trying to create a Place call step in my lab script i get the different checkboxes to edit with variables. When i gets to the Call Contact variable i cannot figure out what type of variable it should be. I have tried Integer, Boolean and Prompt variable but it wont recognize anyone of these. Does anyone now where i can find this types of example variable types that can be used with the steps within a script or does anyone know what type of variable i can put as the Call Contact parameter. See attachement for screenshot of te Place call step.
hani_altaher Wed, 05/03/2006 - 23:23
this variable type is Contact , you have to define new variable with Contact type and then assigned it to Call Contact variable.
borban Tue, 05/23/2006 - 01:44
No, you can not define any variable to use for this purpose. Try it yourself, or You have some other version of CRA (3.1(1))?
