SSL VPN Client
May 4th, 2006
Hi everyone,
I am doing some testing with the SSL VPN Client and i seem to be having an issue. The first connection will work ok, launches the SSL VPN Client installation and connects without any issues. The issue i have got is that once i disconnect the session and then try to reconnect, it just either hangs part way through the Client installation or fails to establish a connection.
Anyone got any suggestions ?
Cisco SSL VPN Client version (CISCO STC win2k+ 1.0.0 1,1,0,154 Mon 01/09/2006 10:24:54.43 ) is enabled
Cheers
Wayne
murphyw Wed, 05/10/2006 - 04:52
This was fixed with the latest revision of the Concentrator image.
