Secondary Addresses
Answered Question
May 4th, 2006
Looking to know if a secondary address will automatically become the primary if a primary address also configured on a FastEthernet LAN port is removed, or will it be removed as well?
interface FastEthernet0/0
ip address 10.24.216.1 255.255.248.0 secondary
no ip address 10.40.80.1 255.255.248.0
Correct Answer by Harold Ritter about 11 years 3 months ago
The primary can't be removed unless all the secondaries are removed first. If you try to remove the primary, you will get the following message:
R1(config-if)#no ip address 192.168.1.1 255.255.255.0
Must delete secondary before deleting primary
R1(config-if)#
Hope this helps,
Overall Rating: 5 (1 ratings)
Correct Answer
Harold Ritter Thu, 05/04/2006 - 03:30
  • Cisco Employee,
R1(config-if)#
Hope this helps,
