having trouble redistribute a eigrp route into BGP
May 4th, 2006
We are in the process of implementing a vendor supplied MPLS WAN which uses BGP between the CE and PE routers. We are using EIGRP on the current Frame-Rely LAN\WAN
i cannot get BGP route into EIGRP in router C
eg
Router A
router eigrp 123
redistribute bgp 45678 metric 2048 1000 255 1 1500 route-map redistibute_bgp_eigrp_next_hop
network x.x.x.x
no auto-summary
router bgp 45678
no synchronization
bgp log-neighbor-changes
network x.x.x.x mask 255.255.255.0
redistribute eigrp 123 route-map redistribute_eigrp_bgp
neighbor x.x.x.x remote-as xxxxx
no auto-summary
router c
router eigrp 123
network x.x.x.x
no auto-summary
mounir.mohamed Thu, 05/04/2006 - 05:44
  • Gold, 750 points or more
Based on the above configurations there is nothing wrong but could you provide us with the route-maps lines even the ourput from the show route-map redistibute_bgp_eigrp_next_hop.
Best Regards,
Mounir Mohamed
mounir.mohamed Thu, 05/04/2006 - 05:48
Note: My request based on there is redistibution has been done well and the bgp route shown on the show ip route eigrp in router-A
cisand2002 Thu, 05/04/2006 - 16:48
hello,
Can you add this under your bgp process :
router bgp 45678
bgp redistribute-internal
and let me know.
baldy Mon, 05/08/2006 - 00:38
Have you checked that the redistributed route is sitting in the EIGRP topology table on router A? Just cos its in the route table doesn't man its in the topology table. If not, you can't expect C to have it either. If it's in A's topology table but not C's then you may need to restart the EIGRP peering to kick it into life. EIGRP can be funny like that.
