Warning message
anup.anand Fri, 05/05/2006 - 06:06
  • Silver, 250 points or more
As per the dial-peer command, you can have more than 2 billion dial-peers.
(config)#dial-peer voice ?
<1-2147483647> Voice dial-peer tag
But the number of dial-peers you can configure would be limited by the physical memory. Couldn't find any doc that says how much memory is used per dial-peer. May be someone else can shed some light on this.
I did a quick check in my router by monitoring the memory usage before and after adding a dial-peer. It seems to use close to 4 KB per dial-peer. This value is not be accurate as something is always happening in the box.
Anup
