vpn max user concurrent sessions question
May 5th, 2006
Can anyone who knows about VPN concentrator answer the following please?
From what I see from the Cisco VPN comparison webpage, 3020 supports max of 750 users with 256MB.
My enquiries are:
(1) Is VPN box memory (256MB for 3020) the main factor for determining the max concurrent user for this 3020 model?
(2) Is 256MB the base memory for 3020 model, or rather is 750 users the base (minimum) users for the model? Can we customize the 3020 model to support 200 users first, then upgrade later?
(3) For the 3005 model, is the 100 max concurrent users limited by the 32MB memory in the box? So with 64MB, 3005 would be able to have max concurrent of 200 users?
Thank you.
stomasko Fri, 05/05/2006 - 05:29
  • Silver, 250 points or more
Max users is also a funciton of the number of SEP processors as well as the type of encryption hw vs sw. Keep in mind 3005 and 3015 use software encryption which is part of the limiting factor with these two models.
