MGCP--- Dial-peer!!!
CCM4.13 with 2811 T1 PRI MGCP.
It might be a stuipd question, but I just so curious.
Usually, it will generate default dial-peer like following:
dial-peer voice 9991023 pots
application mgcpapp
port 1/0:23
For some reason, my configuration doesnt have any dial-peer, but it works... no problem for incoming and outing call.
Anyone knows why??
Ken
jaregalado Fri, 05/05/2006 - 10:20
Hi Ken,
MGCP is a master/slave protocol that allows Cisco CallManager to take control of a specific port on a gateway. This has the advantage of centralized gateway administration and provides for largely scalable IP Telephony solutions. With this protocol, the Cisco CallManager knows and controls the state of each individual port on the gateway. It allows complete control of the dial plan from Cisco CallManager, and gives CallManager per-port control of connections to the public switched telephone network (PSTN), legacy PBX, voice mail systems, plain old telephone service (POTS) phones, and so forth. This is implemented with use of a series of plain-text commands sent over User Datagram Protocol (UDP) port 2427 between the Cisco CallManager and the gateway.
All of this means that specific dial-peer are not necessary on the voice gateway because all the call routing is a responsability of the CallManager.
More information can be found on this document:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00801da84e.shtml
Regards.
