VG 224 and CCME fax service over h323. How To?
Hi, I have a vg224 and a ccme configured with SCCP and stcapp, like this schema shows:
[PSTN]---(E1)---[CCME]---[VG224]
But now i have to attach multiple fax on the vg224 ports, so the only way to relay fax between PSTN and the vg is using h323 or mgcp.
My knowledge of h323/mgcp protocols is poor and I only find specific documentation about vg224 with sccp examples.
I would only need a very little configuration example with a vg and a ccme router connected through h323. Any specific documentation is welcomed.
