Calling number, Sip Trunks and Asterisk .
Answered Question
May 8th, 2006
A 7960 forwards calls not answered to a number thats routed over a sip trunk to an Asterisk server. Asterisk sees the Caller Number as the 7960.
So when asterisk has played its various messages and forwards the call back to an AC broadcast queue i see the caller number as the original forwarding phone not the original calling number of the customer.
I'm guessing its an Asterisk issue but could it be SIP ? If i forward the phone to another CCM extension I do see the original calling number.
Matt.
Correct Answer by gogasca about 11 years 3 months ago
Im running CCM 4.2SR1
7960 CFNA --> SIP TRUNK --> * ---> extensions.conf --> Go to CCM again ---> we see 7960 not very first-
In the CCM Side in the SIP trunk make sure you have the following:
Outbound Calls
Calling Party Selection* Originator
Here in mylab works fine:
105 IPC --> 102 CFA to 210 --> in * 210 send it back to 101 and in 101 phone I do see 105.
Outgoing call leg
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 110.10.200.3:5060;branch=z9hG4bK3fdd7fba
To:
Date: Tue, 09 May 2006 05:39:45 GMT
Call-ID: [email protected]
Supported: timer
Min-SE: 1800
User-Agent: Cisco-CCM4.1
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: "IP Communicator" ;party=calling;screen=no;privacy=off
Contact:
Diversion: ;reason=unconditional
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 227
Incoming call leg
05/09/2006 00:39:45.500 CCM|Incoming UDP SIP message size 698 from 110.10.200.2:[5060]:
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 110.10.200.2:5060;branch=z9hG4bK0fdf17b2
To:
Contact:
CSeq: 102 INVITE
User-Agent: Asterisk PBX
Date: Tue, 09 May 2006 05:35:38 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER
Content-Length: 238
It works fine also for my PP (109). I used First Available algorithm and I do see Original calling party number. Can you give it a try?
exten => 210,1,Dial(SIP/[email protected])
Under CCMAdmin| Service | Service Parameters | TCD (Telephony Call Dispatcher)
Make sure you have these:
Redirect With Directing Party CSS* True
Reset Original Called Party on Redirect* True
//G
Overall Rating: 5 (2 ratings)
Correct Answer
gogasca Mon, 05/08/2006 - 21:49
  • Green, 3000 points or more
Outbound Calls
Outgoing call leg
To:
Supported: timer
Min-SE: 1800
CSeq: 101 INVITE
Max-Forwards: 70
Contact:
Expires: 180
Content-Length: 227
Incoming call leg
To:
Contact:
CSeq: 102 INVITE
Content-Length: 238
//G
