LMS 2.5.....Unable to see devices on the other side of the firewall
May 8th, 2006
We are using LMS 2.5.1.I have added my Pix firewall in DCR & also added pix firewall's IP as seed device.Still I am unable to see devices on the other side of the firewall.In the Campus Manager Pix Firewall is shown as unconnected device.
Please help.
Overall Rating: 4.8 (5 ratings)
miheg Mon, 05/08/2006 - 23:28
  • Gold, 750 points or more
I assume SNMP connectivity to the devices behind the firewall is fine?
You probably need to define a seed device behind the firewall as CDP probably doesn't pass the firewall.
Cheers,
Michel
David Stanford Tue, 05/09/2006 - 05:06
  • Cisco Employee,
This is true, remember that CDP is layer 2 and won't pass through the firewall
nitinmathur Sat, 09/02/2006 - 06:04
I understand VMS is used for managing PIX. But Is it possible to enable snmp on PIX and collect snmp traps and logging from pix on a LMS server.I am trying this snmp string etc is configured properly but it is not discovering pix.
pls suggest
David Stanford Sat, 09/02/2006 - 07:58
  • Cisco Employee,
Do you also have an snmp-server host configured on the PIX which has the IP address of the LMS server? Need this in addition to the snmp comm string for LMS to manage it
nitinmathur Sat, 09/02/2006 - 19:55
Hi Davi,
Thx for your email. Yes I have configured snmp-server host configured on PIX with the string. Moreover I have checked on pix by
debug packet inside src any dst udp
it tells me that pix inside is sending something to LMS srv on port 162. But don't know why lms srv is not showing that. Also the logging is enabled on pix.
David Stanford Sun, 09/03/2006 - 16:44
  • Cisco Employee,
162 are snmp traps, probably sending these, but LMS is not a trap receiver for PIX
Any traffic on UDP 161 or 514 between the server and PIX?
nitinmathur Mon, 09/04/2006 - 00:50
I have got it working as it is !!
Just that we have to manually add PIX Firewall in LMS at
RME > Device Mgmt > RME Devices > Add Devices
It is showing PIX config as well.
