Warning message
HELP - Pix to Pix VPN on 2 interfaces
May 9th, 2006
I am really stuck on this one. I want to configure a VPN between 3 pix 515 devices. PixA will connect to PixB and PixC, but pixB and PixC will not connect directly.
I have successfully created the VPN between PixA and PixB. I am now trying to configure PixA to connect to PixC on another interface (ethernet2), and the ISAKMP phase 2 is failing with a "SA NOT ACCEPTABLE" error. I relaxed my acl to accept any ip, but am no farther ahead.
Questions:
Can I use the same ACL for both tunnels?
That is what I am trying to do...
Can I simply create a new map and apply it to ethernet2, and use the same isakmp policy?
Here is the crypto / isakmp configs. Again, PixA to PixB works. PixA to PixC does not.
PixA:
ip address outside xxx.yyy.6.19 255.255.255.248
ip address inside 192.168.3.5 255.255.255.0
ip address outside2 aaa.bbb.80.80 255.255.255.0
access-list 101 permit ip any any
access-list outside_access_in permit ip any 192.168.3.0 255.255.255.0
access-list outside_access_in permit ip any aaa.bbb.80.0 255.255.255.0
access-group outside_access_in in interface outside
access-group outside_access_in in interface outside2
sysopt connection permit-ipsec
crypto ipsec transform-set strong esp-aes-256 esp-md5-hmac
crypto map map1 1 ipsec-isakmp
crypto map map1 1 match address 101
crypto map map1 1 set peer xxx.yyy.6.20
crypto map map1 1 set transform-set strong
crypto map map1 interface outside
crypto map map2 1 ipsec-isakmp
crypto map map2 1 match address 101
crypto map map2 1 set peer aaa.bbb.80.90
crypto map map2 1 set transform-set strong
crypto map map2 interface outside2
isakmp enable outside
isakmp enable outside2
isakmp key ******** address xxx.yyy.6.20 netmask 255.255.255.255
isakmp key ******** address aaa.bbb.80.90 netmask 255.255.255.255
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption aes-256
isakmp policy 1 hash md5
isakmp policy 1 group 5
isakmp policy 1 lifetime 86400
PixB:
access-list outside_access_in permit ip any host 192.168.1.0
ip address outside xxx.yyy.6.20 255.255.255.0
ip address inside 192.168.1.17 255.255.255.252
crypto map map1 1 set peer xxx.yyy.6.19
isakmp key ******** address xxx.yyy.6.19 netmask 255.255.255.255
PixC:
ip address outside aaa.bbb.80.90 255.255.255.0
ip address inside 10.10.10.17 255.255.255.252
access-list outside_access_in permit ip any host 10.10.10.0
crypto map map1 1 set peer aaa.bbb.80.80
isakmp key ******** address aaa.bbb.80.80 netmask 255.255.255.255
I would really appreciate any help you may offer.
P.O
dmease Thu, 05/11/2006 - 01:48
You cant use the same access list for two different tunnels. When the packet gets to the PIX, how will it know which tunnel to go down?
Are the networks the same at site B and C? What are you trying to achieve?
