Warning message
MCS Server Sizing
May 10th, 2006
Just looking for a general idea on MCS server sizing for CCM and IPCC Express. I understand actual sizing needs to be done by a partner with the Cisco tool.
My understanding from SRND is that all servers within a CCM cluster should be the same size (7835's, 7845's, etc.).
Does that mean my IPCC Express servers should be the same size/model as well?
Conceptually, would it be ok to use 7845's for my CCM cluster and 7835's for IPCC Express? (provided the sizing is independently appropriate).
Thanks.
Overall Rating: 5 (1 ratings)
thisisshanky Wed, 05/10/2006 - 11:58
  • Purple, 4500 points or more
The choice of servers for IPCC express is completely independent from Callmanager hardware. Regarding the servers in the CCM cluster being the same, its generally a good practice to keep them all the same. (Though, you definitely can have a 7835 for your Subscriber and 7845 for Publisher, no big deal).
Now for IPCC Express, the choice of server requirement is based on, many factors.
a. Just like Callmanager assigns weights to devices, IPCC Express assigns weights or points to various features such as (number of Recording sessions, number of Historical reporting sessions, ASR/TTS, total number of agents, supervisors, IVR ports etc. If your server doesnt meet the total number of points required for all the features you need, then you need to use the next higher model. So a 7825 has 900 points, 7835 has 1266 points, 7845 has i think about 3400 points. You have to use a spreadsheet available for download (called CRS configuration tool) which tells you the right hardware you need for the IPCC features that is required for your call center.
7845s are same as 7835s except that 7845s have dual processors, 2 extra hard disks, RAID 5 etc. You may need a 7845 if you need upto two HR sessions during business hours.
Sankar
PS: please remember to rate posts!
