05-10-2006 03:07 PM
Folks,
I have ciscoworks 2.5.1 running in my lab. I had to install Dec 2005 patches and many more patches to get it to work. My question is that if i oreder 2.5.1 and install it would i need to install any additional patches to get it to work?? any known issues
05-10-2006 04:03 PM
I am guessing you meant LMS 2.5 initially, as the Dec updates were actually LMS 2.5.1
If you order LMS 2.5.1 it would take you up to service pack 3 of each component, you could then just add the latest service pack, 4, to get additional device support and bug fixes.
05-10-2006 05:10 PM
many thanks for the response. can i order lms 2.5.1?
If Lms 2.5.1 is available would I have to install service pack 4 on top of it to make sure that i do not run into any issues? I will surely rate this post.
05-10-2006 07:10 PM
I believe that all new orders of LMS will contain LMS 2.5.1
If you receive LMS 2.5.1, then you may install service pack 4 on top of it.
If you already have LMS 2.5 and would like to install service pack 4, then you have to go via LMS 2.5.1 first. If that is the case, then you may download LMS 2.5.1 from (this requires LMS 2.5 to be installed first):
05-10-2006 07:11 PM
I just checked and LMS 2.5.1 is orderable as either an upgrade from a previous version of LMS (2.0, 2.1, 2.2) or as a full version.
It is a good idea to install service pack 4 on top of it just to add new device support and any bug fixes. However, the application will work fine without service pack 4 installed.
05-11-2006 05:19 AM
I will surely rate this post. I do not see anything says service pack 4 on cco under ciscoworks download page, but if i go under lets say campus manager i see download option for 4.0.4, is that service pack 4?
05-11-2006 05:24 AM
For service pack 4, you need to download it for each component: Common Services, RME, CM and DFM
You would go to the link for each product and then downloads
05-11-2006 05:21 AM
05-11-2006 06:00 AM
Yes, that is Service Pack 4 for Campus Manager.
You may find Service Pack 4 for Common Services, RME, and DFM in the same manner.
