Warning message
DCDirectory - DSA Replication warning
May 11th, 2006
I'm getting this DSA Replication warning in my Event viewer. "DSA REPLICATION[18]Proc. 1021 Sev 14."
"DSA has been lost." Does anyone know what this means and if it's something I should be concerned about?
milay Thu, 05/11/2006 - 19:06
  • Cisco Employee,
Yes, you should be concerned. This is telling you the pub's DCDirectory can not communicate with one or more of the subscribers to replicate it's data. This can eventually cause issues with Directory on the pub, best case.
Have you removed or reloaded any subscribers in the cluster recently? If yes then you need to get rid of the old replication agreements. If not you most likely have an issue with name resolution.
I can not stress this enough, MAKE SURE YOU BACKUP DCD & ENSURE YOU HAVE ALL NAME RESOLUTION ISSUES RESOLVED BEFORE YOU UTILIZE THIS PROCEDURE!
Look to this link to resolve your issue. This link needs the CCM releases updated but it IS valid for all 3.x & 4.x versions. If you do not feel comfortable executing then please pen a TAC case, as you have potential to loose all of your directory configuration.:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008012b3c3.shtml
Mike
