Warning message
Cisco 2821 Advanced IOS ver ( for IPSec support)
I have a Cisco 2821 model with following ver and memory available. I want to upgrade the IOS to advanced IOS for IPSec support. Will the existing flash mem will support advanced IOS ?. What is the path in Cisco site for downloading advanced IOS software?.
Raju
fss#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(7), RELEASE
SOFTWARE (fc6)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 01-Mar-06 07:22 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
fssbomh uptime is 2 weeks, 2 days, 19 hours, 27 minutes
System image file is "flash:c2800nm-ipbasek9-mz.124-7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2821 (revision 53.51) with 196608K/65536K bytes of memory.
Processor board ID FHK1007F24W
2 Gigabit Ethernet interfaces
4 Serial(sync/async) interfaces
2 ISDN Basic Rate interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
fssbomh#
cisand2002 Fri, 05/12/2006 - 02:23
c2800nm-advsecurityk9-mz.124-7.bin
min 256MB DRAM -- you have 196608K/65536K
min 64MB Flash -- 62720K
so for me it should not be a problem
but to dowload it you need cco login
To create a CISCO.COM (CCO) account, go to http://www.cisco.com and press the Register link at the top of the page.
HTH, please rate if helps.
cisand
