Warning message
a.giorgi Fri, 05/12/2006 - 15:42
I suppose came enable by default.
The main difference are:
- Costs: The maximum value in RSTP is 2000000
- Port states:
STP RSTP
Disabled Discarding
Blocking Discarding
Listening Discarding
Learning Learning
Forwarding Forwarding
- Edge ports
More rapid convergence
I recommend to read the next doc: http://www.cisco.com/warp/public/473/146.html
I hope this help (please reate if it does)
Alberto
Francois Tallet Fri, 05/12/2006 - 21:49
  • Gold, 750 points or more
This is the default on latest CatOS release, but not yet on IOS (it's on its way though). You can enable Rapid-PVST by just setting the mode (spanning-tree mode rapid-pvst). Note that you can also run an IEEE-like RSTP, with only one instance, by using the mst mode with no configuration.
Francois
carl_townshend Thu, 05/18/2006 - 07:18
does it make much difference than normal STP ? Also whats the differences in the IOS'S ? Is the CatOS on high end switches ?
gpulos Thu, 05/18/2006 - 07:33
  • Blue, 1500 points or more
it does make a differnce over STP as the algorithms are more efficient to allow for more rapid spanningTree convergence in the event of a topology change. (quicker network recovery than with normal stp)
CatOS is used in some of the 'higher' end switches but is starting to be phased out for IOS Switch versions. (helping to keep all cisco OS versions more similar)
