Warning message
2821 MGCP not registering with CCM 4.1
May 12th, 2006
Hello, I am trying to get an E1 Q.sig up but the gateway just won't register with the Call Manager, here is the relevant config being used:
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
no logging event link-status
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
mgcp
mgcp call-agent 172.23.2.5 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
When issuing the show ccm-manager command I get this:
MGCP Domain Name: AFIGW2821.yourdomain.com
Priority Status Host
Primary Registering with CM 172.23.2.5
First Backup None
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 00:57:01 UTC May 13 2006 (elapsed time: 06:33:04)
Last MGCP traffic time: 07:29:44 UTC May 13 2006 (elapsed time: 00:00:21)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 172.23.2.5
Current Link State: OPEN
Statistics:
Packets recvd: 0
Recv failures: 0
Packets xmitted: 0
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, port 0
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
Download Attempted : 1
Download Successful : 0
Download Failed : 0
Configuration Attempted : 0
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command:
Configuration Error History:
FAX mode: cisco
and when debuging for mgcp packet I can see them comming and going:
*May 13 07:31:14.290: MGCP Packet sent to 172.23.2.5:2427--->
RSIP 78495923 [email protected] MGCP 0.1
RM: restart
*May 13 07:31:14.294: MGCP Packet received from 172.23.2.5:2427--->
500 78495923
I am kind of desesperate since everything seems to be fine, could anyone please give me a comment?
Overall Rating: 5 (1 ratings)
Steven Landon Sat, 05/13/2006 - 02:00
can you post a screenshot of your CCM config?
i suspect that the MGCP name in CallManager is not AFIGW2821.yourdomain.com
You should either remove the domain name in the gateway or make it correct and use the full name in the CCM configuration.
Steve
jmthewissen Sat, 05/13/2006 - 08:06
That did it. Removing the domain name on the router allowed it to register inmmediattly.
thanks!
gajolly Sat, 05/13/2006 - 05:11
hi,
as in the previous post please paste the screen shot of CCM config and make sure you have updated entries in LMHOST...
