IOS Upgrade through console in cisco 2500
May 14th, 2006
I want to upgraded ios in cisco 2500 router . kindly advise me in this regard
thanks in advance
thanks
*2500 console do not support console rite ?
william2u Sun, 05/14/2006 - 17:40
are u sure 2500 do support xmodem for Console !?!?
csco10837896 Sun, 05/14/2006 - 20:02
If you are in rommmon mode try following command:
connect router e0 to machine ethernet with cross cable.
following are list of command:
IP_ADDRESS=PC GATEWAY IS THIS IP
SUBNET_MASK=SAME AS YOUR PC
DEFAULT_GATEWAY=YOUR PC IP
TFTP_SERVER=YOUR PC IP
TFTP_FILE=WHICH IOS YOU WANT TO UPLOAD,IT MUST IN THE TFTP DIRECTORY.
tftpdnld.
I think this will help you.
Please rate this,
regards,
Yogesh
