Warning message
LMS-acs integration
May 15th, 2006
hi,
My ciscoworks cs-acs application regrestration have been failing. i have provided all acs information according to the documentation onto lms yet the application regristration failed. any usefull advice would be appreciated. thanks
Overall Rating: 4 (1 ratings)
andrewswanson Mon, 05/15/2006 - 02:29
  • Silver, 250 points or more
i had a similar issue. check if your ACS has an IP filter to prevent unuathorised devices connecting. go to Administration Control - Access Policy and add your Ciscoworks IP to the range of allowed IPs
mdazadzaki Mon, 05/15/2006 - 17:02
Thanks for the advice. now the application has successfully registered with acs, and i can see the ciscoworks applications on the shared profile components. many thanks
