Warning message
No Traffic after multilink PPP Multilink
May 15th, 2006
Well, recently we did a ppp multilink bundle between 2 locations. 2 T1 links were bundled together. After the bundling, there was no traffic passing through the multilink interface. I had to shut down the interface on the adjacent router, only then would the traffic flow through the multilink interface.Please find attached the configuration. Thanks in advance
Rathish
junaid.butt Tue, 05/16/2006 - 04:08
what is service policy on the serial interface? secondly you should define the configuration on MLPPP bundle instead of idvidual link. Here is example which i am using:
interface Multilink7
description Multilink
ip address 10.10.11.13 255.255.255.252
ip tcp header-compression iphc-format
load-interval 30
ppp multilink
multilink-group 7
hold-queue 1000 in
hold-queue 1000 out
ip rtp header-compression iphc-format
interface Serial3/1/5:0
description DPLC 1
bandwidth 2048
no ip address
encapsulation ppp
load-interval 30
ppp multilink
multilink-group 7
interface Serial3/1/6:0
description DPLC 2
bandwidth 2048
no ip address
encapsulation ppp
load-interval 30
ppp multilink
multilink-group 7
interface Serial3/1/7:0
description DPLC 3
bandwidth 2048
no ip address
encapsulation ppp
load-interval 30
ppp multilink
multilink-group 7
regards
-JB
rathish_ram Tue, 05/16/2006 - 11:39
Hi Junaid,
I got it resolved. The issue was with the delay factor on the Multilink interface due to which EIRGRP was not routing packets through this link.
interface Multilink10
bandwidth 3072
ip address 10.250.254.122 255.255.255.252
ip route-cache flow
delay 2000
ppp multilink
ppp multilink group 10
service-policy output DG_Multilink
interface Serial0/0/0:0
description *** Chicago to Orlando
bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
ip rtp compression-connections 254
interface Serial0/0/1:0
bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
Rathish
