BOOTSYS
ankurbhasin Mon, 05/15/2006 - 22:07
  • Red, 2250 points or more
Hi Ali,
AFAIK this command is only used to set the boot path for the image in the flash or network.
You can use boot system command to boot your switch directly from tftp server but that will not copy the image into flash of the switch but it will directly load the image into DRAM.
Have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_r/ffrprt2/frf010.htm#wp1017705
HTH, if yes please rate the post.
Ankur
ankurbhasin Mon, 05/15/2006 - 22:31
Hi Ali,
Somwhow I believe it is best to have the image copied to the on board flash and then set the boot path to boot image from flash.
Use copy tftp flash command to copy the image to flash and later set the boot oath for the new image.
Ankur
