Warning message
Etherchannel
Bobby Thekkekandam Tue, 05/16/2006 - 10:05
  • Cisco Employee,
Hi Neo,
Although the terms are generally used interchangeably, "Load Sharing" is probably the more accurate term.
HTH,
Bobby
*Please rate helpful posts.
glen.grant Tue, 05/16/2006 - 10:06
  • Purple, 4500 points or more
Technically it is load balancing with the traffic divided over the links depending on either the ip addresses or mac addresses in the conversations .
