T.37 OffRamp Faxing Using Cisco 3825 Router and Unity IP Fax Service
May 16th, 2006
Hi. I already have a Cisco 3825 with 2 T1/PRI with a Cisco CallManager cluster using MGCP. Now the client would like the ability to send faxes from the desktop using the unity ip fax service. I know T.37 OffRamp works with H323 but can I have MGCP on the router for the 2 T1/PRI and then configure H323 for the 3rd T1/PRI to be use for incoming/outgoing fax using T.37??
Any ideas?
Thanks in advanced,
-Jose
Markus Schneider Thu, 05/18/2006 - 08:05
  • Cisco Employee,
Yes, the only limitation is that the PRI's that are used with MGCP won't be usable for T37.
