Warning message
password recovery of 7609
May 16th, 2006
I am facing a problem while recovering the password of 7609. When router goes to Romon mode after pressing break key and i configure
confreg 0x2142
reset
boot
it doesnt bypass NVram
attached herewith is the show version output of the router
i really need it urgently
mahmoodmkl Wed, 05/17/2006 - 00:13
  • Gold, 750 points or more
HI
From u r output u r config-register value is still 0x2102.
can u try this
config-register 0x2142
then do a reload
thanks
Mahmood
zahid77 Wed, 05/17/2006 - 00:42
yes u r right but i did this experiment but as i told that after configuring this 0x2142 value it doesnt by pass nvram. i took this show version output before configuring its config-register value
it is giving me some boot error
lenmc Wed, 05/17/2006 - 07:26
Try typing 'config-register' then 'return' and follow the prompts hitting 'return' until you get to the nvram line, type 'n' then complete the options with 'return', save the change and reload, this should bypass the config.
