QOS Prioritizing Traffic Problem
Remote office/Cisco 1841
I am puzzled.
The "show policy-map interface" shows the correct class-map (priority),
shows that there are plenty of packets that have been processed through the
priority class-map. Everything looks OK except for the "Packets marked 0"
piece. I don't understand why that doesn't show a non-zero number.
List below is my config.
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
memory-size iomem 25
clock timezone NewYork -5
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
class-map match-all priority
match access-group name priority
policy-map outbound
class priority
set ip precedence 1
bandwidth 768
class class-default
set ip precedence 0
fair-queue
interface Null0
no ip unreachables
interface Serial0/0/0
description $FW_INSIDE$
ip address x.x.x.x
ip access-group 103 out
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
max-reserved-bandwidth 100
service-policy output outbound
encapsulation ppp
ip route-cache flow
service-module t1 timeslots 1-24
ip http server
ip http access-class 1
ip http authentication local
ip access-list extended priority
permit tcp any any eq telnet
permit ip any 192.168.0.0 0.0.255.255
sh access-list
Extended IP access list priority
10 permit tcp any any eq telnet (44906 matches)
20 permit ip any 192.168.0.0 0.0.255.255 (19774 matches)
Serial0/0/0
Service-policy output: outbound
Class-map: priority (match-all)
64711 packets, 13911001 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name priority
QoS Set
precedence 1
Packets marked 0
Queueing
Output Queue: Conversation 266
Bandwidth 768 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
2909411 packets, 492075275 bytes
5 minute offered rate 1000 bps, drop rate 0 bps
Match: any
QoS Set
precedence 0
Packets marked 88296
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
ahmed-hussein Wed, 05/17/2006 - 20:22
It's better to modify the configuration as below
class-map match-all priority-in
class-map match-all priority-out
mach ip precedence 1
class-map
set ip precedence 0
Policy-map inbound
class priority-in
set ip precedence 1
policy-map outbound
class priority-out
bandwidth 768
class class-default
fair-queue
interface
service-policy input inbound
interface
service-policy outbound
Ahmed Hussein
mounir.mohamed Thu, 05/18/2006 - 01:09
  • Gold, 750 points or more
Dear smartin,
Its seems that there are no packet matched by the class-map priority due to ACL behavior which is (If match Then Stop) so i beleive that the below configurations example will achive your needs ISA.
Ex1:
match access-group 101
policy-map Outbound
class priority
bandwidth 768
set ip precedence 1
class class-default
set ip precedence 0
fair-queue
access-list 101 permit tcp any 192.168.0.0 0.0.255.255 eq telnet
Ex2
match protocol telnet
class-map match-all address
match access-group 100
class-map match-all parent
match class-map address
match class-map priority
policy-map outbound
class parent
bandwidth 768
set ip precedence 1
class class-default
set ip precedence 0
fair-queue
access-list 100 permit ip any 192.168.0.0 0.0.255.255
Please Let me know the results
Best Regards,
Mounir Mohamed
Core Engineer
NOOR Advanced Technology, SAE
